Gen 3 question
Jaynen
Replacing the headlight bulbs, connector pulls off, then you are supposed to pull the rubber part out, remove the spring replace bulb and do the reverse. I am kind of worried about yanking too hard on the rubber gasket like thing? Maybe it's just not something you should be doing in 33 degree weather and I need to get it warmed up a bit?
Sabre
Overlanding Nurse
I've been trying to finish up some work on mine and things are a bit stiff with this weather! Including my fingers....
Wait...you can actually fit yours into your garage? I can barely walk through mine! :D
Goldenbora
