Gen 3 Strut Assembly measurements
Offroadmuch
I was wondering if anyone has a front strut assembly handy for some measurements? I am specifically wondering how far apart the three upper mounting bolts are and if they are evenly spaced? I am asking because I am trying to find out if Toyota or some other more common brand has the same bolt pattern/measurements for the use of spacers up top. This would be cheaper than ordering 35mm spacers custom made.
Thank you-
nckwltn
I just tossed my old struts a couple of weeks ago. I think the three mounting bolts are evenly spaced, but if you pull off the air intake box, you can get access to the bolts on the passenger side
MoabRefugee
Thank you-
95mm between bolts, 85mm ID/135 OD per this this thread
https://www2.pajeroclub.com.au/forum/showthread.php?t=18617
Offroadmuch
I thought I read someplace on ExPo that Autozone guarantees parts forever. Would that include a set of struts/shocks? If anyone knows from experience? I will ask in person at the store when I get a chance.
Houie
