Gen 3 - uneven tread wear - front negative camber?
SampaGuy
I have noticed my front tires have significant uneven tread wear on the inside of the tire, as if the car has too much negative camber in the front. When I look at the car sitting still, everything looks straight enough to the naked eye. On the rears, the tire wear looks nice and even. I want to address this if possible before I put new tires on, can you guys tell me which suspension components I need to check? I'm thinking UCA and LCA bushings? Is there camber adjustment in the front, is it possible that it just needs to be adjusted?
When I did my brakes, I looked at the ball joint bushings and while it is in one piece and not cracked, it did feel worn as it felt a bit too soft?
