GEN1 Passenger Bouncy Base
chadzeilenga
I finally got around to installing the drivers Bouncy seat I pulled out of a GEN1 in local yard into the passenger side of mine.
A few things:
1. There were no bolt holes for the rear mounting tabs (bolt #5 & 6) in the floor pan
2. The rear tabs interfered with the floor pan and I had to bend them slightly so the front (4) bolts would fully thread.
3. Adjuster is on drivers side of base, I couldn’t figure out any way of flipping this.
Was there anything I missed that I should have done for this install?
Pic below:
There may be 3 different style bases. The one you have with 6 mounting bolts. A similar frame with only 4 bolts. And an early 4 bolt frame. The early 4 bolt frame has a tension adjustment handle that can be flipped from the left to the right.
chadzeilenga
Thanks, the rear tabs appear to be added onto the frame, so probably a change at some point to add the rear straps.
