MascotRejct
So when I bought the truck back in November, I tore it down to the head gaskets and replaced a bunch of stuff (timing belt, water pump, rear cam seals, valve seals, upper and lower radiator hoses, thermostat, temperature sensor, crank bolt, spark plugs, spark plug wires, spark plug seals, valve cover gaskets, coolant, oil (have done another change about a month ago, I drive 80 miles a day to get to work), transmission fluid) and just the other day replaced my brake pads (the front inside pads are wearing unevenly, any cause for concern? it looks like on piston is either not retracting all the way or the other is not pushing out all the way). Anything else I need to do in your guys opinion before the inevitable 3 day camping trips hauling the boat across the mountains this summer? I have noticed quite a bit of play is present in the rear diff, as evidenced by the loud thunk at low speeds when going from off throttle to on. Would changing out the diff fluid help with that? Sorry for the wall of text, just want to make sure I don't screw up the camping trips that me and my friends use our vacation time for!
