Getting water out
currypinz
Happened to me. Took out the entire carpeting and ripped out the factory standard clothlike soundproofing and threw it away as it was retaining foul water and stank. Replaced with rubber based soundproofing which does bot soak water
Hilux Vigo SAS on 35"
Pinzgauer P93 6x6 718M
1stDeuce
Sounds like you've got a good handle on it. Getting the carpet and padding out and getting it clean and DRY is key. Don't be afraid to really soak any muddy carpet with a garden hose, and use the shopvac liberally. :)
On Liberty's specifically, there's a power center of sorts under the driver's rear seat IIRC. If it got wet/muddy, make sure you clean the crap out of that sucker, and dry it really well. Corrosion at that area has caused vehicle fires... It does not like being wet, even occasionally.
Then realize that your Jeep isn't magic... It's made of the same components that are in a Ram, or a Chrysler 300. If you continue to flog it at every mudhole you see, you'll have LOTS of issues pretty quickly. (Do I sound like your mother/father?)
Oh, and make sure the door drains aren't filled with crud too, so they don't rot out from the inside. :)
At least it wasn't salt water, and you really weren't in that deep...
C
Clemtiger84
