Global-Expedition-Truck on MAN 19.403 FALSX military chassis for sale - private -
Tesomobil
General Informations
- Year of manufacture 2015
- GVWR 14.000 kg (30.865 lbs) - maximum 19.000 kg (41.888 lbs) heavy duty
military chassis
- Dimensions 7.460 mm x 2.500 mm x 3.740 mm (24'47" x 8'20" x 12'27") L x W x H
- Wheelbase 3600mm (11'8")
- 6-cylinder, 12 ltr. Diesel engine with Intercooler and hydraulic fan, 403 HP
- 16 Speed Eco-Split-Transmission, manual gearbox - Topspeed 75 mph
- Non-permanent all-wheel-drive 4x4 with differential locks in front and rear axle
- Parabolic leaf springs front / self-leveling air suspension rear axle
- Fording depth 1.400mm (4'6)
- Tires "Michelin" 14 R 20 tubeless, single tires, special rimbs on the rear axle for
quick tire change
- 2 seperate 80-Gallon-Diesel-Tanks (total 160 gallons = or 1900 miles range)
9,8 mpg (US)
- Additional heated diesel filtration (SEPAR)
- 2 air suspended power seats within heating in the drivers cabin /
add. 3rd middle seat / roof hatch
- LED power bracket above drivers cabin 7200 lumen
- Lots of outside stainless steel storage capartments / generator
Cabin / Camper Box
- Outer dimensions of the cabin 5.020 x 2.500 x 2.000 mm
(16'47" x 8'2" x 6'56") L x W x H
- 3-point kinematic attachement with main and flex mounts for torsion-free
body coupling chassis frame
Self supporting fiber sandwich plate panel 60 mm (2.36") with polyurethane
foam insulation 3mm (0.12")
reinforced fiberglass outer surface, 2 mm (0.08") inner surface
- No cold briges
- Entrance door constructed of same material 60 mm (2.36")
- Tripple sealed doors and storage compartments with heavy duty locks
- Mosquito door behind entrance door
- Dounle insulated thermal window glass with sun blocker / Stainless steel
hinges throughout
shutters and mosquito net by leading german window producer
KCT-Feinste-Technik
- Skylight / panoramic roof hatch over the bed
- Seating area for 4 persons, with adjustable table in the left hand side of
the cabin
- Double bed with suspension and ventilation with comfortable matress in
the back of the cabin
size 1.400 mm x 2.000 mm (4' x 6'7")
- Combined shower and toilet room with porcelain water cassette toilet with
air condition / window
wash basin and mirror / lots of storage for beauty stuff
- Kitchen 2.100 mm (6'89") fully stainless steel countertop with double sink /
3-plate propane cooker & oven
- 130 liter (34,34 us gallon) fridge with small 3* freezer
- Furniture is built to highest professional standards made of white
hpl-covered plywood
- Waterproof venyl floor 6 mm in old auktree optic
Heating System
- Eberspächer diesel water-heating-system combined with engine heat
exchanger and add. webasto air-booster for heating during driving or as a
backup system in case
- Truma E4000 gas heating system
Electrical Equipment
- Control panel / power management / monitoring of battery and liquids from
german quality provider "philippi"
- Battery main switch / fault breaker
- DC power supplied by gel batteries 2 x 210 Ah
- Battery capacity 210 Ah on 24 V or 420 Ah on 12 V
- DC/DC converter 24 V to 12 V
- AC/DC charger 26v - 45 Ah (on 110 to 230 V shore power) for 3 diff. battery
groups
- Inverter 24 V to 230 V continious output 1.300 W
- Shore power from 110 to 230 V
- Power plugs for 12, 24, 110, 230 V
- Solar power system 24 V 200 W or 12 V 400 W (depends on connection)
charging chassis and cabin batteries
- fully off grid !
Lighting
- 10 LED overhead lights in the cabin, above bed, seating area, kitchen, bath
and shower, guest bed
- Storage room lighting under bed and in the electric room in front of the cabin
Water supply
- 400 liter (105 us gallon) freeze-proove fresh water with treatment system and
filtration
- 90 liter (23,78 us gallon) freeze-proove grey water tank below the seating area
- 25 liter (6,6 us gallon) freeze-proove black water cassette
- 20 liter (5,28 us gallon) freeze-proove hot water boiler/heate-exchanger with add.
electrical heating combined with diesel heater
- City water connector with pressure reducer
Vehicle is currently located and registered in europe (germany) but can be
delivered and licensed in USA. Everything onboard. Ready for the big journey !
This is a real custom camper built on prooved travel experiences out of
20 years through North- and Southamerica, Europe and Africa.
Best available materials installed !
You do the import paper work I'll do the shipping and delivery to your
destination.
Interested ? pls contact me via web page tesomobil.de or on fb "tesomobil"
275.000 USD - !!! free shipping to your destination !!!
Goldenbora
