Good deal on BIG winch
piercearrowinc
Supporting Sponsor
We are pretty proud of our 20K and proud to be part of the portal! We've seen it break 1/2" cable. It is a heavy beast. The price includes the roller guide, hook, snatch block, cable, and single solenoid assembly.
For limited time, we'd like to offer free shipping on the 20,000 lb. winch to Expedition Portal members only. To validate this offer plug in promo code 20KPORTAL into your shopping cart. The shipping method will say “Freight: we will contact you.” Continue with your order and we will honor the promo code and ship the 20K for free. Offer ends May 1, 2010.
jesusgatos
How would that winch compare to the 10,000lb Garwood PTO-driven winches on the old deuce and a halfs? Mah Deuce weighs 16,000lbs empty, and I'm well over 20,000lbs when loaded and towing a trailer.
piercearrowinc
Supporting Sponsor
I spoke to Tim at Aluminess and got the dims for a pre-2008 Ford van bumper. You have 33" x 9 7/8" x 10.6" clearance within that winch mount. Our PS20000 measures 23" x 7.7" with a clutch that is 9 3/4" high. The clutch would have a tight 1/8" clearance. Our PS12000 might be a better fit. For the PS20000 or PS15000 you would have to relocate the solenoid assembly. The assembly attaches to the winch motor and does not have mounting holes for relocation purposes. An easy fix is using a our P039 solenoid cover with steel mounting plate and P215F plug. We can pre-wire the set up and mount the solenoid on to the plate for you.
Psyph
