arveetek
Lastly I want to figure out how to wire the stock Blazer tail/brake lights so I can plug them into the 4 pin of the RV so I can ditch the magnetic trailer lights.
I recommend these diodes from Roadmaster:
HY-POWER DIODES
Discover top-quality tow bars, braking systems, and RV accessories at Roadmaster Inc. in Vancouver, Washington. Enhance your RV experience with reliable and innovative products designed for safety and convenience.
Essentially, you cut the factory wiring going to the taillight, then splice one diode in on each side. You will have two inputs and one output: one input is the factory wiring and the other input is from the 4-way from the motorhome. The output goes to the taillight. Makes it a cinch and keeps everything working properly so there's no backfeeding through the turn signal switch. Simply run a dedicated, permanent flat 4 wire from the front of the Blazer to the rear, and then use a short quick-disconnect cable between the front of the Blazer and the rear of the motorhome.
You don't need a diode on the clearance/running circuit, as it can power up all the clearance/running lights on the Blazer with no problem.
Casey
