Halft Built Expedition trailer With extras!
71Swinger
have a half built expedition trailer located in Salt Lake City, Utah. I started it about 3 months ago then lost my job and ran out of money. And now leaving for the army in a couple months... So I need it gone asap!
Ok like I said it is half way done! It has a little surface rust that can be cleaned up with a wire brush WD40 and 5 minutes. I did the hardest part of the entire build. You got one perfectly squared frame made from 3 inch channel. And measures 75"x49" the cross members are 2x3x3/16 angle iron. The front tongue is also 3inch channel and has a 2inch receiver welded in so you can make it an adjustable length tongue. It has a brand spankin new set of tires that are Jaxxon ST205/75D15 with a 5on4 1/2 bolt patter(same bolt pattern as Most Jeeps.) And a brand new Hendersons trailer axle 61 inches wms to wms. I will also throw in a brand new pintal hook rated at 5Tons(about $65 new) and a brand new pintle ring rated at 7Tons(about $50 new) as well as a 4 wire trailer plug for your truck($20 bucks new) and a 4 wire wiring harness for the trailer($20 bucks new) and 2 oval trailer light brackets($10 each new and I think I might have 1 LED oval light some where if I can find it I will throw that in too). I will also through in my 2 cents on how I was going to finish it if you would like. Or if you dont have the time or the tools to finish it your self if you pay for the steel and a little extra for my supplies and time I would be more than happy to finish it for you how ever you would like it! We can work just about anything out! Let me know
Asking $700 for every thing OBO maybe trades depending on what it is. I own a Jeep TJ and a First gen 4Runner.
JPT4648
