Clark White
I have a Yaesu 7800R and a Diamond Antenna SG7900. I will be mounting the antenna on the side of my roof rack. I want (I'm told it is the best/close too?) to use RG8X Coax and am planning on building my own cable (I do this every day for a living, so I am confident I can do a good job). However, at work we look in a parts listing for the plane, order a mil-spec part, and never have to research manufacturer or specific versions, so while I can do the work, I'm at a loss what parts to order or where to get them from :smilies27. I know I need a UHF/PL-259 connector on the radio end. I then want to put a panel mount connector in the roof (rather then running through door seals or just having a wire pass through). What panel mount should I use, and what connectors go with that? I thought I could just use an 90* SO-239 (like factory Diamond Antenna coax), but I cant find what connector will thread on to an SO-239 besides the antenna. Then for the antenna, I know I need an SO-239, but I would like to get a 90* like what comes on the factory Diamond Antenna coax, any idea where I can get those from? I'm assuming I want gold plated for these, but I don't know enough about them to know which manufacturer is the best, which versions are best, etc.
Thanks!
Clark
Note: On the planes, we use RG-178? and either mini UHF or BNC, so I don't have anything to compare specific connectors to.
Thanks!
Clark
