I need to remove and modify my flip-pac for a bit. The camper weighs about 300lbs. When I was modifying my camper I had the use of my buddy's forklift which was nice, but now I don't have that option. I recently ordered some CR Brophy cable camper jacks(74") from JC whitney but after they should up to the house the poles were missing. Upon talking to the customer service I found out that they no longer supply the 74" poles. Why did they sell them to me? I have no idea, and I could not get a reasonable answer. Anywho, I would love some alternatives if any one has any ideas. Oh and it would be nice to keep the cost under $300
I tried to order from JCW also, the description was not very clear and I ended up being sent two sets of two 74" poles but not the rest of the jack. At that time (JCW stock seems to come and go) they listed the shorter pole jacks which I ordered but they cancelled the order because they didn't have them in stock. These jacks are hard to find and I ended up ordering a 3000# set with the shorter poles from a different supplier and used one set of the 74" poles from JCW for those jacks. It sounds like dealing with FRP some. After I bought them I found an almost new set on Craigslist for $100, oh well.
If you have a small truck the shorter poles should work fine. I needed the long poles because my truck rails are almost 60" off the ground.
The jack base was too close to my truck wheels so I welded up some extensions that work great. For some reason I replaced the steel cable with stainless cable, I must have been thinking of leaving the camper on them outside. I really like the Brophy jacks and despite the many concerns I have read about stability I think they are very stable and easy to use. If anyone is interested in seeing how I did the jack extensions I could take a photo of them.
