Superu
Never used Beaver Tuff-Pull
This is a great unit, but needs have changed and I'd like to see it go to someone who has the time to put it to use. Includes winch, cable (still on original spool) and handle. Winch is $359 new.
Yours for just $200. Paypal preferred.
Local pickup preferable but will ship for $36. Remote locations may incur UPS surcharge (Truckee, CA for example)
Sample image:
Will add pics of actual item soon.
Manufacturer's description:
The Beaver Tuff-Pull Recovery Winch is identical to the Black Rat 4WD Recovery Winch except for color. They are lightweight, fast, simple and safe to operate. Rated at 3,500 lb single line deadlift capacity, this manual winch can be used in horizontal, vertical or angled working conditions. Capacity ran easily be tripled to 10,500 lbs using snatch blocks. With this winch, you can pull your vehicle from the front, rear or sides. It is also very handy for farm, shop or construction work. The unit is easily transferable from vehicle to vehicle.
The 30 pound winch is built with a tough steel housing and high quality machined steel components for ease of operation. Overloading is prevented by the use of a shear pin located in the forward lever, which will shear at 125% of rated maximum capacity. The broken pins can be replaced without removing the load and spare pins are conveniently located in the lever handle. Each winch includes 66 feet of high quality cable mounted on its own storage reel. The cable is fitted with a safety latch hook at one end and is tapered at the other end for easy access into the unit. The handle collapses to 25 inches for storage and telescopes out to 46 inches for greater leverage. Each full stroke cycle advances the cable 1. 1 inches.
Sample image:
