Handbuilt Titanium FORM Cycles Prevail 29er Hardtail, Overland Journal Build-Super trick, Like-New, Durango, CO
I'm selling this titanium FORM Cycles Prevail 29er. There's a lot of reasons to be interested in this bike, but the one that stands out is that this is an Overland Journal build, complete with clear coated Overland Journal graphics.
Bike is in like new condition and has some amazing hand-built and custom touches:
-Hand-built (in Sedona, AZ) titanium frame, approx. size L. Made in the USA.
-Overland Journal build adds drop-outs for touring racks. Super cool!
-TruAtiv Hammerschmidt All Mountain 2-speed front drivetrain/crankset/bottom bracket. Amazing engineering; see diagram and description below
-SRAM X-9 Rear Derailleur
-SRAM X-0 Shifters
-SRAM Code R brakes
-RockShox Reba RLC Ti 29 fork
-Cane Creek headset
-TruAtiv Stylo bars
-TruAtiv Stylo Stem
-Thomson seat post
-Fizik Aliante Ti saddle
-Velocity 29" tubeless wheels with Hope Pro II hubs
-Newer Maxxis Ardent 29"x2.25 tubeless tires
-Shimano SPD pedals included with sale.
A couple very light scuffs on the frame from cable rub, but aside from that, this could be considered as like-new condition all-around.
Hand-built titanium sexiness at around 20lbs, unique, collectable and just plain awesome.
Asking $3699.
Available for viewing by appointment at Purgatory, CO (north of Durango), delivered to Overland Expo West in Flagstaff on the weekend of May 19th or expertly boxed and shipped for the real shipping cost. PayPal please add 4%.
DESCRIPTION
The Truvativ HammerSchmidt All Mountain Crankset could revolutionize bicycle drivetrains from this point forward by eliminating that last bastion of low-tech: the front derailleur. Gone are the days of jammed or dropped chains, missed shifts, and bent cages. The move is in favor of a seamless and bulletproof system that magically squeezes two gears out of a single chainring. The best part is that it will shift in any condition -- load or no load -- any time you wish.A system of planetary gears contained within HammerSchmidt's surprisingly compact and thoroughly sealed housing yields either a 1:1 or a 1.6:1 Overdrive gear ratio. Thus, a single 22T chainring delivers 22/36T versatility and a 24T ring provides the same range as a 24/38T. All along, the chain is held on tight by the included chain guide and you even gain more ground clearance, too. If you're envisioning downhill security with all-mountain versatility, you're on the right track.Even better, this wizardry comes with only a modest weight penalty and virtually no increase in Q-factor. At 1623g, a complete HammerSchmidt All Mountain system adds less than 180g to a comparable setup using a Truvativ Stylo two-ring crank and chain guide. It offers more reliable, faster shifting, and it's tough as nails and way, way cooler. The Truvativ HammerSchmidt All Mountain Crankset will only mount on frames with ISCG 03 or ISCG 05 tabs, and it requires the use of the matching HammerSchmidt bottom bracket and trigger shifter. Crankarms are available in both 170mm and 175mm lengths.
quigleyth
