Headlight restoration
Cackalak Han
First, I don't know if this belongs here, as it's not really a modification, but I thought maybe it would help some out that have been plagued with the same dull headlight oxidation I was suffering from. :)
After trying to get around to it for many many months, I finally got some time (and motivation) to do it. My lights didn't look horrible, but definitely oxidized. I can't remember where I saw the write-up, but it called for 1500 and 2000 grit sand paper (which I found out I can only get at an auto parts store, not Home Depot or Lowe's), and PlastiX polish. Well, I'm cheap and impatient (not a good combo :D), so I opted for just the 2000 grit paper and already had some Mother's Plastic Polish on hand.
The lighting is pretty bad, so sorry about the quality of the pics, but the lights look worse than they appear.
I started with the wet sanding. Only did about 2-3 minutes worth of sanding.
Did that, dried it off, and applied some of the plastic polish. Buffed. (Only passenger side is done)
Close up
Simple as that. Really made a big difference. When I was buffing the polish off, I thought that it didn't make any difference, but stepping back and looking at both lights, it's like night and day. So, total time spent of less than 20 minutes was well worth it. If any of you are looking to do this, DO IT.
spunky2268
Mother's
Nice work! I, too, had the dreaded dim eye... I'm a stickler for keeping my headlamps clean when traveling and was looking for something to perk them up. Kit scratch remover and a Mother's Power Ball made all of 10 minutes work for me to brighten them. Makes them easier to keep clean, too.
wentz912
From another board I got the idea of using some whitening toothpaste and a dry rag. You can just use the cheap stuff from the dollar store or whatever, along with any kind of clean dry rag that you've got laying around. works pretty good for what it costs you.
DenCo40
Awesome write up. I need to do this to mine. I bought polish but just doing that alone didn't do a whole lot. I'll have to round up some 2000 grit and try it out!
Thanks
xander69
