discocolin
Hi guys, I have a 99 D1. I was installing hella ff500 driving lights and got all done with everything, tried them out and nothing... I think I heard a slight pop when we flipped the switch. NOW THE FRONT AND REAR PARKING/running LIGHTS ON THE LEFT SIDE DONT WORK??? I check the fuses, all fine, bulbs fine, is there a reason one side would work and not the other. Now I found out what we did wrong, the + and the - switched around on the new fog light switch. The problem is I was using one of the old extra front parking lights that I no longer have because I have a new bumper. I used that as the green "turn on" lead going to the foglight switch. I think I fed too much juice to it, what would that have done? How do I fix it? Is there a inline fuse somewhere for each side? could I have blown those little lighting diodes that I saw in the back? any help would be much appreciated.
Thanks,
Colin
P.S. I just moved out from FL to NM, I am loving this truck more by the min. out here!!! It is perfect for the terrain out here.
Thanks,
Colin
