Looks like probably a ten pounder. Also looks to not be an original Power Tank cylinder, atleast I don't remember any bare aluminum ones. The handle and gauges could be Power Tank brand. Not that it really makes a difference whether the cylinder was from Power Tank, they all serve the same function. Price wise I can usually build a similar setup for about $150, so the price is fair if the gauges and regulators work. The cert date is stamped into that upper section, they usually have 5 year certs. Wherever you get it filled can usually recert, or whoever they send it to, last one I remember was $20-30 to get new cert. That hose looks a little iffy for freezing up, but those can be found for pretty cheap.I have a line on this Power Tank CO2 bottle setup for $150. The seller does not know the size. Also, where do you check to see the certified date? How important is the date? Can they be re-certified? The price seems fair...is it?
Thanks!
It actually could work to your advantage that it's not a real Power Tank, just pull the handle and regulator and exchange where you get it filled. You might not have to pay for cert, and get a "new" tank in exchange, then put your own stickers on it. It's cool having a unique tank but it is more work to try and hold onto a specific tank most of the time.
Thanks!
