Cheepjeep85
First off i'd like to say hello, this being my first post I thought it would be rude to just start asking questions. I've been lurking around for a while now, and I'm in the middle of a trailer build, using half of a Jeep tub with a home built storage box on the front, and a home built trailer frame, sitting on 33x12.50x15 tires.
I'm to a point where I need to start building a rack for my smittybilt overlander xl rtt, and it's heavy, 150lbs roughly, with a 800lb capacity. This rtt will sleep 4 adults easy, so it's likely that it will see capacity. My plan/question is this, I have 1x1 14 gauge tubing for the rack, I'm thinking it's going to have 3 (for lack of better wording) "support hoops", and of course be tied together for the rack. To add to it, I'm going to make it height adjustable, I have some 1.25x1.25 11 gauge tubing for the 1x1 to telescope into. Range of motion will be 16".
Does this plan and or materials sound like it's going to be sturdy enough? Should I change anything?
Thanks in advance.
Thanks in advance.
