Help With Solar Panel System
TheJosh
I found a couple solar panels today and I'm thinking about setting one up on my roof of my 4runner. Still need to clean them up and figure out all that I need. Here is a pic of the panels and the rear info sticker
I plan on keeping one and selling the other
I have a national Luna dual battery setup with a blue top as a aux
What do I need to hook this up?
Here is the specs I found:
Solar Power Panels 50-VLX-53
53 Watts - 3.08 Amps
(LxWxH) 36.9x19.8x0.9
limited 10 year warranty for 90% of rated output $396.50
TheJosh
Jonathan Hanson
Congratulations on the panels. One 50-watt unit will significantly enhance your charging system. However, don't expect 50 watts out of it. You might approach that on a 40-degree perfectly sunny day with the panel aimed directly at the sun, but most times it will be producing significantly less. Just so you aren't disappointed if you install a monitor.
Also, make sure the panel isn't regularly shaded by anything else on your roof. Even partial shade will shut down a PV panel.
