Help
jasonL_031
ok i wired my fog lights a few months ago and since then i have had some problems well only one i had the lights working all the way to calgary during dec but on the way back they stoped working it has happend before but i dont remember how it fixed it self any suggestions would be wicked thanks Jason.
Check all wires.. Make sure they aren't broken, loose or grounded..
Make sure you've got a good ground.
Check the fuses.. You did use fuses right..??
Check the bulbs
Check the switch
Check the relays.. You did use relays right..??
That about all it could be..
Check your grounds at the lights and relays.
Check your connections.
Check you connections if you tapped a lighting circuit for a feed
are your lights grounded to the bumper? if so, run a ground wire from the bumper to the frame or, better yet, directly to the battery. You could use one side/color of a jumper cable as a temporary ground - for testing purposes.
OchoSolo
