Hidden Goal Zero Yeti Lithium 400
dr_r2r
I wanted to utilize the huge storage area at the boot of a 2005 Porsche Cayenne. So I installed my Goal Zero Yeti 400 lithium in it. It’s going to be there semi permanently since it’s heavy to carry it back and forth out of the car. Now I have access to 12v/ 2 x 110v/ 4 x usb without affecting the car’s electrical system. It tucked in really well and it still has enough space for a bigger unit plus accessories. It also freed up an awkward space occupied by the GZ in the boot and it is hidden when not in use.
shade
Looks good. I'm guessing you charge it in place. Did you make a shelf for it? I can't quite tell from the photos.
dr_r2r
Yes. I charge it in there either by solar or the car. It’s just a temporary shelf that I bolted it on. I got a couple of aluminum panels that I saw in Ebay and I want it to be portable as well. I’m just amazed at the huge unused space in the Cayenne. I’m pretty sure that it would also fit in a couple more lithium batteries or a larger capacity Goal Zero.
flipstick
