I've done some web researching with Kelvin ratings and such when I purchased two sets of IPF 968s last year. I compared different reflectors the best I could, and looked at replacement bulbs too. The only thing I didn't do was look into aftermarket HID kits to replace the Halogen bulbs. I know these kits have been around, but they were pretty expensive, and perhaps they didn't have H3 bulb kits available back then. I remember wanting the Hella 4000 HID lights, but those were way over priced. Of course, they're so overpriced that Geico would have paid for most of the "loss" if it was damaged or stolen, but it would still be no fun having to pay $500 every time someone got rich.
The IPF 968s are pretty nice. I think they're pretty good for the price. I have 3 on a lightbar I got from Randy Ellis Design in Phoenix. The middle one is aimed a bit higher/farther, and it's on a separate switch. With the 100w bulb that's included in the kit, it lights up the trail/road pretty good. I've been thinking about mounting the forth one somewhere in the rear, as the other day driving through snow, I ended up at a dead end, and I couldn't see POOP backing out at night in the heavy snowfall.
Anyhow, I just checked, and it appears the H3 style Xenon bulb just won't fit in the IPF housing. The Xenon bulb is too long, and the shape of the reflector also doesn't seem Xenon friendly with the multi-reflector design. I'm sure it'll be brighter, but also somewhat prone to theft. Without the ignitors and the ballast, I'm guessing it'll be worth near $300.
I started thinking about HID recently because I discovered that ACA Performance had started making kits including the entire housing/assembly, projector lens, bi-xenon bulbs, ballast, ignitor, all other wiring and etc. Best of all, it's DOT approved. The Kelvin rating is 4200K, with 3200 lumens of light output. No blueish tint, and much brighter than Halogen. The housing looks solid, even though I haven't seen it in person, and the installation process looks much easier than when I installed my IPF lights. The only drawback is its cost. MSRP is $1000, I believe.
Here's some photos and info from a fellow CTer (Customtacos.com) of mine:
http://www.scott-industries.com/projects.html
Then ACA's website:
http://www.acaperformance.com/
I found a source to buy the kit somewhat discounted, but it's still in the air as he needs 4 more people to get in on the deal.
You've mentioned due to the color, you wish you had Halogen in inclement weather. What was the Kelvin rating? With the ACA kit, I'd have to buy a new set of bulbs if I choose to use 3000K bulbs rather than using the included 4200K bulbs. I understand that the higher the Kelvin rating, the less usable light there is, and more glare. Since most cars that have HID in stock configuration have 4200K bulbs, I was hoping the glare won't be as bad, and it won't make it too hard to see in wet road/ground conditions. Or perhaps the kit you've experiemented with were so bright that it was as if you had bright auxiliary lights on.
Anyhow, any info is appreciated on this subject! Thanks all!
