Kinda, I have used my bed mat once and it worked out well but I sure wasn't going to cut it. Other ideas are the strips of carpet. Check with a remnant shop and see if you could pick up some, you should be able to get something like a 12"X 4-5ft strip for next to nothing. Where are you going that requires sand mats?
find an old snowmobile track and cut her up to size, they make the best sand mat for basically free.
the coast here in texas there is a very good fishing section called big shell beond a seran point is 4x4 only and it way only be me and another truck but if carpet works im in luck cuz i can get carpet for free most of the time thanks for the advice everyone
haha, another PINS thread.
there are no trees there. you're lucky if you get stuck near a washed up buoy or some of the other large debris, which you can use as an anchor. an 89 bronco will be fine out there. i always see plenty of full-size trucks and SUVs. like 7wt said, it's all in the technique. you can for sure get stuck out there, but usually only if you want to.
when will you be down there?
