Home made solinoid box?
mantree91
I got a smoking deal on a (ab)used smittybilt winch. It's not too bad but they somehow wrecked the plastic box that houses the solinoid. Has anyone ever built a replacement box? What did you use?
Sent from my SM-G930V using Tapatalk
RedF
Does your winch use the typical 4 solenoid setup? This would be an opportunity to upgrade to a contactor type solenoid and do away with the enclosure all together.
mantree91
It is a single unit. You are saying it can be run without a box for protection?
pugslyyy
It's going to take 4 DC power solenoids (also called golf-cart solenoids), about $50.
CampStewart
I agree 100 percent. Even if you have the original solenoid pack one or more may be internally damaged from the blow that took out the enclosure. It may work fine now but I wouldn't trust it out in the middle of nowhere in bad weather conditions.
RedF
I ran one for several years "exposed", only bolted to the front of the rad support.
mantree91
I guess I'll look in to getting a new one, even if I just keep it in the tool box like I do with a spare alternator.
DaveInDenver
Middle Income Semi-Redneck
A photo may help explain what you're talking about when you say replace the 4-solenoid package with an enclosed contactor. There are variations on the exact brand, model and connections but the essential part is they are sealed unit that can completely substitute functionally for the original solenoids.
  • Like
Reactions: plh
plh
yep, I mounted mine on the engine side of the radiator support
Houie
