Honda Generators For Sale ***BOTH SOLD*** Thanks
doug720
I have 2 small Honda generators for sale in SoCal. I would prefer pick up, as shipping may be difficult as they have gas in them.
Both were used as back up for our motorhome and trailer to run battery chargers if needed.
#1 - ***SOLD***Honda EU1000***SOLD***
It is in very close to new condition and works perfectly. Very small and light, extremely quiet, auto-idle, with direct 12 volt charging and a factory cover.
#2 - ***SOLD*** Honda EX650 - ***SOLD***
This is in very good condition and is a true generator, not an inverter type. This is a sought after unit that is one of the quietest generators Honda ever made. Small, light, direct 12 volt charging with factory cover.
Both start easily and are always stored inside with proper fuel protection so no gummed up carbs.
Both will run for over 4 hours on 1 gallon of gas.
doug720
EX650 pictures:
doug720
White cover is EX650
Silver cover EU1000
doug720
A weekend bump...
Kind of sad that I have had several members of Forums I belong to and respect contact about these generators. 2 of them said consider both of them sold and they would pick them up the next day...So far, no contact from them! Plus I told others they were sold! I trusted them...
Now, they are for sale until picked up!
Sorry for rant
doug720
The EU1000 sold to EP member David today...Enjoy and thanks!
The EX650 is available. It is a dam good generator that is incredibly quiet.
doug720
Depends on the AC's power requirements. The unit should have a rating plate on it that lists watts and amps to run it.
Generators have a peak/start rating and constant load ratings. The maximum power output of the EX650 is 650 watts. Running on alternating current (AC) power, it is rated for a voltage of 120 volts at a frequency of 60 Hz, ampere of 4.6 amps, and a constant power output of 550 watts. DC outut, 12 v DC 8.3 amps. Starting system, Recoil starter. Fuel tank capacity, 0.8 gallons. Running time, Over 6 hours - Per Honda Manual -
dwh
Tail-End Charlie
Any idea if the 650 could power a small trailer AC?
Your trailer have some special ultra-low-power a/c unit? Maybe.
Roof mount RV type - no chance whatsoever.
Cheapo 5k BTU from Home Depot - no chance whatsoever.
dwh
Tail-End Charlie
A few months ago I would have jumped all over that 650 for running a battery charger (could run up to a 30a charger).
But then I fell into a killer deal on 300w of solar and haven't run my battery charger since.
Still...if this thing doesn't sell in a month or two (Winter Is Coming!), I will almost certainly snag it whether I need it or not. :)
