How are you guys routing your rack lights 2nd gen Taco?
jgpoirier
I have a Prinsu rack and finally have all my lights and OTTRAW switches here to be able to install. Curious how you guys are routing your rack wiring into the cab? Also if you're using regular wire loom, or are you using a jacketed wire from the fixture into the cab?
Cheers
MTaco
I don't have roof lights but I did run my antenna for my satellite radio out through the 3rd brake light then behind the headliner and down under the kick panel. Then you could add a quick disconnect between the cab and the roof rack. Curious what others have done.
Andy@AAV
Old Marine
I ran mine under the hood hinge then up in the channel on the windshield seal. Then I put a notch in the rubber filler piece above the door to run the wire in at the top of the windshield and out by where I put the QD for my lights.
quigleyth
