I've been repairing/renovating/customizing my old second-hand Skamper for 3 years now, largely on the back of all the helpful folk on this forum. I just keep on discovering new things I don't know but should. My latest need for an education revolves around my propane regulator. When I bought the Skamper, it had the old kind of propane bottle. I got a new one and consequently had to buy a new regulator + hose so everything fit together. Not knowing any better, I went to the store-that-shall-not-be-named and bought a regulator out of the grill accessories department. Seemed to work fine.
I've now learned that I should have a 2-stage regulator (by law) and since I often camp at high altitude, it would be best to have an adjustable one so I can drop the pressure. In starting to shop for a new regulator, I'm overwhelmed by the choices. What do I need to know to get an appropriate regulator? Does it matter if it's vertical or horizontal or is the configuration just whatever fits my storage area? I only use one bottle so I don't need auto changeover. Do you have any recommendations?
The connector hose I was using was just what was fixed to the regulator at purchase, a flexible, hard rubber (?) black hose. New regulators don't generally come with a hose it appears. I know that I need a hose that is meant for propane use. Is there anything more specific I should know (other than matching fitting sizes)?
The current barbecue regulator/hose assembly screws to a yellow, corrugated flex hose that then attaches to a larger diameter rigid pipe that then branches into two copper lines that feed my 2-burner stove top and my (currently non-functioning) furnace. Hopefully, all that's kosher. Previous owners did their own fix-ups and based on some of their other work, I don't have much confidence that what they've done is safe/appropriate.
I know that propane is potentially deadly and I'm sure some will say to leave it to authorized technicians, but knowledge is power. I'm capable, just ignorant until educated. (I plumbed and wired my house.) And yes, I do know how to test the connections for leaks.
Thanks for your advice in advance.
