How do I re-activate my remote door lock/ security fob
Wander
After disconnecting my battery to hook up my winch and aux lights I discovered my key fob no longer " talks" to my D1. How do you reset this?
Daryl
HANDSET INITIALISATION
NOTE: New handsets are supplied in pairs.
If a new handset is required, it will require
initialisation to the ECU using the
following procedure:
1.
Starting conditions: ignition off, doors unlocked,
bonnet switch depressed.
2.
Carry out instructions 3. to 9. within 8 seconds.
3.
Switch ignition ON.
4.
Switch ignition OFF.
5.
Lock doors.
6.
Unlock doors.
7.
Release bonnet switch.
8.
Switch ignition ON.
9.
If alarm is correctly accessed, horn will sound and
LED will light. It is now possible to programme two
handsets of correct frequency to vehicle alarm ECU.
This must be carried out within two minutes.
10.
Press and hold down button on first handset until
dash LED flashes.
11.
Repeat instruction 10. for second handset.
12.
The LED will extinguish if both handsets have
been initialised correctly.
Wander
Wow, that is far more involved than I thought but thanks! I think I will need a helper , stop watch and maybe an elaborate multi- phase planning session!
jgdisco2
Sounds like a project, the red trucks remote doesn't work either
Edit: what/where is the bonnet switch?
Daryl
Hood switch. Open the hood and look on the right hand side. It looks like a plunger that is pushed down when the hood is closed.
Just have your helper stand there and push it down with their finger and release it when you tell them to.
dhuss
