How I convert my JKU daily driver into a "sleeper" in 20 minutes or less.
EricGagne
I'm sure I am not the only one around who wants his daily driver to be just that when he's in the city but turn it into sleeper when going on a week-end camping trip or a 10 days backcountry adventure. I wanted something that I can easily install when needed and can be just as easily removed and stored when not. After searching the internets for a solution I found a youtube video from this guy who built a sleeping platform for his jeep.
I found the concept interesting but I didn't like the hinges in top, I like a completely flat surface. Also, I'm a big guy and I didn't feel 1x6 boards would take my weight without bending when I sleep. And last, I wanted a more height for the storage as a 1x6 really is only 5.5" which isn't that much. So I designed something based on his idea and came up with this. I know, it's not all painted yet, but it won't be for another few weeks as I am running out of time and I wanted to take pictures and do this write up while installing before hitting the road in 2 weeks.
First I put a moving blanket in the Jeep to protect my sub-woofer and the back of the rear seats.
520780
For the frame I used some 2x8 lumber. That gives me a storage height of 7.5" which is great. I doubled the front end boards which gave me two 1.5" surfaces to put 3/8 inserts to screw the covers on. You can see those inserts in the boards on the right hand side on this picture.
520781
Here's the frame inside the Jeep. I only gave it two coats of primer, I saw no need for painting it.
520782 520783
This board is screwed on top of the frame using those inserts I mentioned. I used machine screws because I happened to have a bunch of them, hex bolts would be just as good but the machine screws add a nice touch. The underside only has primer, like the frame. The top has two coats of 100% acrylic latex paint.
520784520785520786
The rest of the frame has 2 removable covers to get access to the inside. Like I said, I want a flat top so I just put some braces inside to prevent them from sliding around. The only things that keeps them down is their own weight and whatever I put on top. Again, just primed inside and painted outside.
520787520788
... 10 files limit. Continued in the next post.
EricGagne
There is a 6" to 7" gap between the frame and rear door. I decided to build a small storage box to fill this gap. I use T-Nuts and hex bolts to bolt it on the frame. It does not look like much but it is actually quite usefull. It fits 3 bottles of propane, 1 gallon of anti-freeze, 1 litre of motor oil, a bottle of radiator stop leak and a bottle of break fuild.
520791520792520793520794
Notice I left a gap on the right hand side. This is very important, that space is required for door hinge to work properly.
520795
There is about 1/2" space between the door and the storage box.
520796
..continued on next post
EricGagne
The front end side has two larger pieces that I trimmed to cover has much space as possible. They each have a 2x4 at the front underside to cover the space between the boards and the back of the seats so the whole platform is flat. They are bolted on that doubled 2x8 that I mentioned before, using the same machine bolts with flat washers.
They have the exact same dimensions but they are mirrored.
520797520798
This shows one of the boards installed along with the two removable boards.
520799
And here is the whole platform with the stuff in the storage box.
520800520801
Now this small storage box has two purposes. When I set up for camp I will empty it, cover it with two boards that I cut just for that so the platform will now be flat all the way to the rear door. None of these bottles will be in the way and my feet won't fall in the gap that would have been there without that box.
520802
You maybe wondering why the box does not extend all the way to the left and why there is a cutaway part on the top, it's simply to match the shape of the rear door
..continued next post.
EricGagne
Using 2x8 for the frame also gives me a bit of storage between the top boards and the back of the rear seats. It can be used to put pillows, blankets, maybe a first aid kit or anything else I can fit in there.
520803
Obviously this whole topic would be useless without measurements so here it is.
Frame
520804
Frame cover - jeep front end
520805
Frame cover - jeep rear end. They are both the exact same size.
520806
Front board. Need 2 of them.
520807
Front board bottom part to show dimensions.
520808
I used 5/8" baltic birch plywood.
*** Note: Some of you may have noticed the front boards are resting against the doors on each side. They were not like that when I originally cut them. I think they've expanded a bit since the temperature has gone up in Montreal since I cut them. Do not compensate for this if you have noticed, I already did in the drawings.
*** Note 2: I did not post drawings and dimensions of the storage box. The reason for this is I think whoever builds this should measure it to make sure it clears the door.
*** Note 3: The attached zip file contains a copy of the sketchup design. Feel free to use, modify, distribute it any way you like.
  • JeepSleepingPlatform.zip
EricGagne
I forgot to say. I bought a Napier Backroadz SUV tent. When setting up camp I will setup the tent, empty the jeep putting everything in the tent, including the ARB fridge.
My gear will be protected from rain and the tent will also serve as a changing room.
DallasJKU
That was my idea also with the tent and I just use a Xprite sleeping pad. I thought about a platform, but I can't lose the use of the back seats for my dog. And as of now I don't have a fridge.
EricGagne
I have not tested it but I plan on securing it to the floor before leaving. I have not yet decided how but I'm Ieaning toward removing the loops on the floor and use simple L shape brackets to bolt it down using the well nuts in the floor
