How to build lexan window on plywood sheet?
buba1
Looking for advice on how to build a lexan window on plywood sheet.
Should the lexan be just glued to the plywood?
PVC cement and PL Premium glued...
Or should the lexan be enclosed in a frame, glued to a frame and the frame attached to the plywood?
Trying to keep things lightweight and cheap.
Window is not supposed to open.
Thanks
tarditi
I suggest you put it in a frame and affix the frame to the wall or sandwich it with a frame "ring" around the window opening. This will give it support around the area where the lexan is actually mounted... or get an RV window fitted.
boxcar1
boxcar1
If you are any where near Astoria OR. Come by the shop. I'll give you all of the RV windows you can carry.
buba1
Thanks for the offer, boxcar
I am not close to Astoria. In Alberta, but I might come one day.
I would have looked for RV windows, weight wise these are heavy, my whole wall is plywood.
RV windows are nice, made out of glass and they also open.
Houie
