sloughboy
I am planning on using gas springs to assist in the lifting and then holding up the pop-up portion of my trailer. I imagine the pop-top will weigh no more than 60lbs. Two questions. First. Should I place two gas springs on the front and two gas springs on the rear of the trailer, or should I place the same number on the left and right side. The attached drawings shows the gas springs on the front (note they will be placed inside the trailer but are shown on the outside for clarity). Second. How can I calculate the force required. I looked at a number of online sites, but there is no direct calculation for this type of application. I wish I could just use actuators but I want to keep the weight down. Thanks a bunch.
