Rockhounder
Hey there, just noticed that my 88 suburban has a slight sag of about an inch on the rear drivers side axle. The rear passenger side also has a little sag, but not as pronounced. This was noticed after I put on 2.5 inch new front leaf springs and rear 2.5 inch blocks. The front is definitely higher than rear, whereas the suburban was pretty level before (except for the same left side slight lower by about an inch over rear axle).
Anybody else experience this? How did you fix it for the simplest way? Overall, I think that if the left rear was raised 1.25 to 1.5 inches and the rear right was raised .75 inches or so, it would even out the stance.
I guess I could get a higher set of blocks, but would like to see the spring sag issue properly fixed versus a stopgap that will affect safety or handling down the road.
Any suggestions would be most appreciated.
Thanks
Paul
Thanks
Paul
