nckwltn
On my '03 limited (3.8L), I did the timing belt a couple of months ago, while I had the crank shaft pulley and sprocket pulled off, I replaced the crank seal. But over the last month after a longer drive, I can still smell a little oil burning. While replacing the drivers side rack and pinion bellows I noticed fresh oil coming down from right where the front crank seal is.
Is there any chance one of the front cam seals are leaking, or is it likely a bad crank seal that I put in?
I was going to replace the cam seals (I have them), but I couldn't get a good grip on the cam to be able to undo the nut that holds it on.
Also, is it possible to pull the cam covers off without pulling off the large accessory mount?
