hydraulic tensioner/adjuster
MascotRejct
From what I read, its a pain to push the tensioner rod back into the tensioner. If I was doing it, I would just get a new one. All you have to do is pull the pin on it...
ljense8
Check the part number post. There is a link for a kit that I believe includes the tensioner for $104
Toasty
I recommend only getting an OEM tensioner, i've seen too many of the aftermarket ones fail within the first 40k. get yourself the tensioner tool or make your own.
nckwltn
Using the proper tool recommended but if not:
1997 montero 3.5 timing belt tensioner pulley: http://youtu.be/Vfp7rH5sZOA
I've used a pair of needle nose pliers. the tension isn't that much... something like 2-4 ft lbs
Also, the rod is super easy to push back into the tensioner... just put it into a vise and close the vise very slowly. if you don't have a spare pin, you can use a small drill bit just as easily
jeep-N-montero
That's what I was thinking, I have several pairs to use.
BOPOH
it's not very scientific method, but i just measured the distance between tensioner puller and its bracket and tighten the new on to the same spec. It looks like both holes should be horizontal when tensioner is released against the belt
Clemtiger84
