I am a #@!!*%$ bonehead
Sabre
Overlanding Nurse
...and I'm man enough to admit it! In fact, I'm at the point in life where I didn't swear but rather just shook my head and had a quiet little laugh.
I'm installing a dual-band ham radio in the Montero and had read the "routing wires through the firewall" thread with interest. Since both the radio and the battery are on the driver's side, I wanted to avoid going over to the passenger side to access the big hole where the main wiring harness passes through. Crawling under the dash, I noted a nice bare spot up high, above the brake pedal. Under the hood, there's a nice clear area above the brake master cylinder. This area is where the fire wall goes from vertical to near-horizontal for a couple of inches, moving back toward the windshield before going vertical again. The nice thing about this spot is that there's no insulation on the inside...that stuff on the inside of the cabin is thick! There's just a thin layer of the stuff in the engine compartment, easy enough to drill through and then trim away to insert a rubber grommet.
So I drilled from the inside after measuring and checking several times. Wow, the metal seemed a lot thicker than I thought! I finally punched through and realized that the firewall here is actually doubled...two layers rather than one. No worries. I could see light through the thin layer of insulation so I put the bit back in and drilled on through.
Sparks! Hmmm...******?
Yes. Yes, I did. I really, really did! :oops:
I drilled straight through the CENTER of the main wiring harness bundle. No, boys and girls, not just a little bit. All the #@!!*%$ way! :Wow1:
The doubled fire wall in this area meant that my measurement was off by a couple of inches, since the two layers are not bent together but rather their radii are staggered. I was drilling only an inch from the radius on the INNER layer of metal, but several inches inside the lip on the OUTER layer. Yes, where the wiring bundle lives.
To add insult to injury, the sunroof was wide open and all the windows were down, and the front end was up on wheel ramps. And dark clouds were threatening. So I got a step ladder out, got my electrical tool box, and wished most sincerely that I could bend my elbows and wrists backwards. I clipped the harness loose from several anchor points but it still meant that I had to work on the damned thing in a cramped location, bent way over the fender, with almost no room to move my hands.
I unwrapped a couple of feet of the black covering, started separating the minute little wires in there and appraising the damage. Jeez, there are scores of little wires in that thing!
In the end I had spliced 19 of the little devils. It took hours to do the splices correctly and to re-wrap and re-anchor the harness. I was reminded, yet again, that I'm not a young buck any more...when I was done I felt like I had been run over by horses. Eek.
But, happily, everything works and I'm now smarter than I was yesterday morning. And I've been able to provide an entertaining little story for your amusement.
Go ahead. I can take it. :sombrero:
nckwltn
@Sabre, mind posting a photo or two of where you drilled? (wouldn't want to drill in the same spot myself).
Also, @SoCalMonty has a roller that he is parting out. If the wiring can come free, and there isn't any difference between the years... might be a good way to pick up a spare :)
Glad you were able to mend it, for real!
Fireman78
You may want to carry an extra fire extinguisher. Just sayin. :D
Sent from my GT-P7310 using Tapatalk 2
Sabre
Overlanding Nurse
Hahahaa...yeah, I'm hoping that I WILL NOT need a spare wiring harness or extra extinguisher!
I'm working a stretch of 12-hour shifts and will try to take a pic when able. On a Gen III Montero the main harness passes through the firewall on the passenger side (USA) behind the glove compartment, then is routed up to the very top and all the way across to the driver's side before heading forward to the fuses and battery. It's safely out of the way for almost any routine eventuality. :D I'm perfectly happy with that location as a place to pierce the firewall, but would drill from the engine compartment next time OR would shield the harness with a sheet of metal. It was the doubled wall that threw the landmarks off by a couple of inches that made the difference.
Hopefully, some other poor sod will benefit from my experience!
Sabre
Overlanding Nurse
Yup, it's all installed. Just have to mount the head unit Thursday when I get a day off.
A whole bunch of other little Montero mods are happening, but I'm waiting for a weather window that coincides with time off to get one last big job out of the way.
Stay tuned for details....:smiley_drive:
SoCalMonty
Ohhhh man!!! I'm sorry to hear that! At least you had the patience and skill to fix it though...and a sense of humor about it, too!
It reminds me of a similar bonehead move. A friend of mine had a VW Corrado G60 (watercooled, supercharged 1.8L) and his rod bearings had been getting louder and louder. He had a small window of time to swing by so I could drop the pan and slap a new set in. Now, you can re-use the rod bolts at least once...but they're "torque to yield" (stretch bolts) so the torque values on the second use are way lower.
I finish in a hair over half hour, and he gets ready to leave...but the car is cranking very slow and won't start. I immediately knew what I did. In my haste, I had torqued the bearing caps to the higher "first use" value, squashing the new bearings too tight on the crank journals.
Whoops!!! I had to loan him my car and spend a few bucks and a few hours making things right again! :p
PirateMcGee
ouch! If it makes you feel better I did a timing chain on my old 4runner and when I was done I discovered I was missing a small hose clamp. I looked every where and couldn't find it so I finally pulled the valve cover and discovered the hose clamp......at the bottom of the timing chain cover below the crank. Had to remove and reinstall evvvvvvvverything.
chromisdesigns
Even the factory guys get it wrong sometimes...back in the day, I had an old Kawasaki 350 triple, eventually needed a top-end rebuild. So I pulled it out, tore it down, and just for fun, went ahead and split the cases to see if I could find out why it had always had a really touchy and hard to find neutral...found the neutral detent ball in the bottom of the cases. Turned out the rotating collar that the ball was supposed to live in had been installed reversed on the shaft, so of course the ball fell right out, probably the first time the bike was ever put in gear! Reassembled it the right way round, and amazingly enough, THERE was the neutral detent, right where it should have been all along!
iStan814
