I need a favor....
doc holiday
Can someone with a stock m416 trailer wheel measure the wheel bore size for me? Also can someone try and thread a 1/2 nut onto the wheel stud?
Tight_wad
I can tell you that a 1/2 nut won't thread on, because they are 7/16" threads on the M416. When I measured the center hub for my adapters, it measured I believe 3 3/4". I could measure the center of the original wheel if you like tomorrow.
Hope this helps
Tight_wad
I re-checked them this morning and this is what I have on the adapter invoice.
Vehicle
3.875 inch hub
5 on 5.5 wheel pattern
7/16" wheel studs
The hub bore that they made is 4 inches.
Hope this helps with the order
DrMoab
Mind if I ask what size of wheel adapters and what you are adapting them to?
I also have a 416 that I need to move the flange out about 1.25 inches with a reduction to 5 on 4.5 so they will match my Jeep wheels. I'm curious if this is somewhat like what you are doing and if so, where did you get them?
Tight_wad
I am using the adaptitusa.com wheel spacers. I went with the 2 inch thick size to adapt down to my Jeep JK wheels. I am running stock wheel back spacing and I wanted to increase the spacing from the frame as much as I could.
DrMoab
Sounds like you are doing something similar to what I need to do.
I want to run the exact same wheel and tire combo I have on my Jeep. This means a 4.5 inch back space and they will not clear the inner fenders that way. So I need to go out as well as reduce from the 5 on 5.5 to 5 on 4.5
flipstick
