Luckychase5
Truck will lol be either the new Ram or Silverado with a 3.0 diesel.
So what do you all think? I’m also not completely opposed to having another 3/4ton truck, I just liked the look of 25-30mpg I the new diesel half tins. And that Ram Rebel diesel looks glorious.
Check the interior construction. Years ago they didn’t impress me. Things may have changed, but IDK.Found this one today...
Palamino Camper
Compact Palamino Camper, 1000 pounds, very good condition. Easy to load and unload, 8 foot,salem.craigslist.org
Going to Alaska means extra weight in emergency gear, parts, recovery, etc. It could still be done on a 1500 but you would have to look at a Four wheel camper or other very light popup and then keep your packing simple.
23mpg driving over the Rockies at freeway speeds? Keep it as you're getting easily five more mpg than I've read with those parameters.![]()
Truck Campers
Looking for the toughest pop-up slide in truck campers? Our campers are built tough with composite panels and aluminum exoskeleton.overlandex.com
I’m leaning towards the Camp-X for myself.
I’d also recommend a 2500, the 1500 diesels only have about 1500lb payloads which you’re going to be exceeding with a camper, gear and people. My Ram 2500 will get 23mpg driving back and forth over the colorado rockies at freeway speeds. If you want a 1500 size truck the F150 heavy duty payload package is what you’ll want to get, 4x4 with a 3.5EB actually has a higher rated payload than my 2500 6.7CTD at about 2600lbs.
This is a common misconception. The roads to Alaska and in Alaska are not difficult or dangerous. The biggest problems likely to be encountered are a flat tire or running out of gas due to poor planning.
