I would like wider fenders for M416
Mayne
Does any one know where I could score a set of wider fenders for my M416. I would like to cover the tires better.
Mayne
Bella PSD
I have M416's and a M116a1 Pioneer Tool Trailer. The fenders on the Tool Trailer look like they may fit the M416. And the fenders on the Tool Trailers are verrrry wide. 13.2" wide!!
Louie
ntsqd
Heretic Car Camper
Failing find ing a source for those you might see if any metal vendors in your area do fabrication work. Might be easiest to just have some made as that shape wouldn't be too hard to duplicate. The 3 pieces to form my semi-ARB front bumper, in 10 ga., were $200 about 8 years ago and that included the price of the steel. I'd expect that fenders (less complicated shape, thinner mat'l) would be about the same now.
UK4X4
Northern freight have military looking fenders in 12" wide, I have modified ones on my trailer....now just have to get the axle shortened....
Desertoutpost
Call Dave at Direct Sheet Metal, San Diego (El Cajon) and tell him what you are looking for. He is the best fab guy on the West coast and has great prices.
CodyLX450
Why not just have the stock ones cut in half longways...and add sheet metal in the center to widen the fenders?
That might be the easiest to make or have fabbed up.
I'm going to have to do something similar with mine
Feileod
Henry Cubilian has a nice set up on his M416 (photo) that would easy for any fab shop to duplicate. He is a member of this forum, I am sure he could give you more info.
60seriesguy
Sorry, guys, I must have missed this one the first time around! As Feileod pointed out, I replaced the stock fenders on my M416 with wider custom ones. I wanted them to serve two purposes:
1. Accomodate the wider tires/axle.
2. Stand up to trail abuse better than the stock ones.
JK Customs in Hutto, TX built them for me about 5 years ago, and they've held up well. I've actually been thinking of having them make me another set that incorporates a mount for a propane tank and offers some protection to the fuel cans mounted on the sides of my trailer.
Rezarf <><
I actually just started some custom fenders today, I will post up a few pics tomorrow. I just bend square tubing and I will skin them with 16ga steel.
Drew
Mayne
Cool thanks,
It looks to me like the fab route may be the way to go. There are a couple of local shops i could look up.
Thanks
Mayne:26_34_3:
Rezarf <><
Here is the route I am heading. I am going to add two spreaders that will determine the width of the fenders and then skin them in sheet metal. Not too hard if you know someone with a bender and the right die. I used 1" tubing in 16ga.
I will fit them before trimming up the ends to length. Lots to do before then :D
Hope it helps.
Rezarf <><
Sure-
First, I had to figure out where I wanted them, so will some scrap steel and a few levels I was able to mock up where I wanted them go.
That made easy work of marking where to cut.
Then I layed them out and marked where I would weld in a few stringers to span the gap. I decided to make the fendres a full 14" wide, and at that width they will fully cover the treads to keep the rocks at bay.
Rezarf <><
Next up was drilling 8 .25" holes to mount them to the sheet metal sides.
Then I added two .75" square tubing to span the gap. Just remember that these two stringers have to be perfectly square or your sheetmetal won't sit flush and it will look like crap. I had to recut one weld due to warping and try again. I won't complete the welds until I can check the fit with some sheet metal.
Then it was time to mock them up on the frame. I have about 3.5" of clearance all the way around. I think they will work just fine. I will add a small shelf in front and behind the fender and that will provide a few more mounts to the frame as well.
The stringers will also be good places to bolt a few things down, maybe an ax or shovel, or even the tongue jack when on trails.
hope it helps!
Drew
