Icom 208H Dual Band 2m/70cm HAM radio system
spressomon
SOLD!
I recently upgraded to a Kenwood APRS set-up and am selling my Icom 208H system. I purchased this new and its been installed in my Land Cruiser until a month ago; no known functional issues. A couple years ago when trying to determine a TX problem I was experiencing I sent the unit in to Icom for checkover and it came back 100% operational (I later discovered a grounding issue with my in-roof mounted antenna).
This is a super compact, high quality, dual band mobile HAM radio system with a large easy to read LCD display. I'm including the bona-fide Icom cloning/programming kit that includes software and required link cable for programming/cloning from a PC; works great. Also included is the 22' extension/separation cable, also an Icom part. And a 1/2" RAM mount system. Please note the RAM mount plate is epoxied to the back of the 208H face so unless you opt to remove the RAM mount plate this face will need to be mounted via RAM mount...which is how I had it mounted in my LC.
Includes all original owner's/operator manuals/information and all cabling mentioned above. You'll need an easily sourced and inexpensive CAT5/6 cable and coupler to extend the mike...as necessary.
Read more about it here: http://icomamerica.com/en/products/amateur/mobile/208h/specifications.aspx
$225
Pick up in Monterey or $10 to ship to any lower 48 state
iStan814
