Hi Guys
Im new to the forum, I have been lurking round for a few months and am gaining lots of ideas from your valuble expertise. I am building a camper on the shortest version of a 416 unimog, so far I have the mog completly restored except for the gearbox which is still good and the camper frame built.
I have a question if the idea I have for attaching the aluminum panels is good or if anybody has a better idea ???
The frame I have built is mostly 3mm steel and between 30 and 50 mm square section, my idea is to cut the pannels to shape and then clamp them in place and mark all around the inside of the frame. Next I will lay the panel down and stick a strip of rubber 3-5 mm thick and 1 cm wide around the whole panel 10mm in from the edge. Following this I will offer the panel back up to the frame and drill holes for rivets 15 mm in from the edge so it passes through the rubber, then lay the panel back down and put a bead of 5200 or 252 high modulus silicon around the 10mm on the outside of the rubber and up to the marked line on the inside of the rubber, then rivet the panel in place. I will put nylon washers on all rivets and also dip them in duralc or Tef Gel to hopefully avoid as much metal to metal reaction as possible.
Is this a good idea or do any or you have any better ideas, time or cost is not the issues, quality of build is most important !!!
Any ideas would be greatly appreciated
Thanks
Sam
Thanks
Sam
