roaming knome
Hello all,
I recently replaced my ISC (Idle Speed Controller) in my 1989 gen 1 Montero because when stopped at a traffic light or stop sign the Montero would die or have very sporadic and rough idle either about to die/stall or want to power surge as if my foot was on the gas pedal. After replacing the ISC it does drive better, throttle seems to roll on smooth and no more stalling or inconsistent idle at stops. However on first start up (cold engine) idle is 1800-2000 rpm and after warm up it drops to the 1100-1400 rpm range but it never really drops below that and the Haynes manual (which is the one I have) has 700 +/-50 rpm for my 89' Montero with 3.0L V6 with auto trans.
That is not the only problem either, once the rpm get to 2500 or accelerating up to any speed the check engine light comes on and stays on until rpm's drop to about 2300 or below. The Montero otherwise drives fine but I would like the idle to be within spec and the check engine light to be off unless there is a serious problem which there might be right now
Any and all help would be greatly appreciated.
