Here's the issue:
Sitting at a light earlier tonight and saw the amp meter needle go down to just above the "1" on the "12" on the gauge. Lights dimmed a bit but it held steady there (this was at a red light at idle). As soon as I got moving again it was up around the ~13V again. This happened twice at two red lights. Just wondering if this is normal, and what your guys's voltage tend to sit at around idle (~750 rpm).
On at the time:
ECON a/c mode
blower fan
OEM fog lights
85W Osram Low Beams (using upgraded wiring and relays)
Radio
Brand New Mitsubishi Alternator
Brand New Optima Red Top
2 Ga Ground Wires
2 Ga Direct Power Wire from Alt to Batt (with 100A breaker)
On at the time:
ECON a/c mode
blower fan
OEM fog lights
Radio
2 Ga Ground Wires
