Inergy Solar Generator
sargeek
I was watching a you tube and the video flashed over this "Solar Generator." The 30 amp RV plug caught my attention. Seems a bit sill to go from 12vdc to 110VAC to use the RV trailer converter to drop it all back down to 12vdc. Also interesting that you can connect this to addiitional 12vdc batteries to get addition run time.
K2 SOLAR GENERATOR
  • Internal Battery: 1,100 Watt hours (90 amp @12.6 volts), Lithium NMC
  • Battery Life Expectancy: Up to 2,000 Cycles or 10 Years
  • AC Inverter: 1,500 Watts continuous pure sine wave, 3,000 Watts starting surge
  • Charging: 500 Watts maximum input, 3 hour recharge time at max input
  • Battery Expansion: Compatible with both 12.6 deep cycle lead acid/AGM batteries & InergyLithium-Ion Batteries (soon to be announced)
  • MPPT Charge Controller: 500 Watt (30A) Maximum Input. Charges in as little as 3 hours in ideal sun conditions.
  • 2 USB-C Charge Ports: 5V 3A
  • 2 USB Qual Comm 3.0 Charge Ports
  • 3 Position Power Switch: Allows user to charge devices via the USB, USB-C, and 12V output ports without having to turn on the inverter
  • Charging Temperatures: 32°F to 104°F
  • Discharging Temperatures:20°F to 115°F
  • Dimensions: 14" W x 7" H x 8" D
  • Weight: 25 lbs.
  • Warranty: 1-Year
  • EC8 Input Plug: Creates an extremely user friendly, plug and play interface
  • Shoulder Carrying Strap
  • AC Charger Included
  • NOT Compatible with MC4 to Neutrik Adapter.
  • ONLY accepts Inergy solar panels, car charger, standard AC charger and Quick wall charger.
  • REQUIRES 30' Neutrik to EC8 Solar Panel Cable to connect to previous Inergy panels.
Thoughts? It seems to have EXPO all over it - looks more fun than a Goal Zero?
john61ct
DIY one that suits your specific needs for a fraction of the price. But these better than most if their detailed specs match your needs and you have money to burn.
Do not call them "solar generators", marketeering deceptive scammer talk.
I would never consider such a **portable powerpak** unit that did not have replacements readily and reasonably available for the internal batteries.
What exact battery chemistry? xPyS layout? watt-hours capacity, at what hour-rate discharge? Rated cycles lifetime if DoD is to the cutoff every time?
Max amps limit for fast charging? What voltage?
What is the built-in solar controller specs for use with generic panels?
What do they recommend you do when the batts need replacing?
sargeek
Who knows it’s suppose to last ten years. It must have a pretty hearty inverter because they comment on it running a washing machine.
john61ct
Not a chance.
Warranty period, sure,
And sure it'll "run" some washing machines, but not for long unless a powerful charge source is also running.
Look at the watt-hours, factor in inverter losses, basic math not rocket science.
Maybe this washer
KurtActual
