Instrument Cluster
Meili
How bad is yours?
I used to restore classic cars.
I have repaired them using a window defogger repair kit.
Takes a steady hand and use thin pinstripe to tape lines.
davispm1
Well sorry I should be clearer, its the whit plastic housing that hold all the instruments. As you can see there is a square were the electric speedo circuit board fits into. Cannot seem to find one of these to buy, here is another picture.
1stDeuce
Try looking for one in a Junkyard. That's really not a "collector" truck yet, and that particular part isn't likely to fail, so it makes sense nobody is re-making it.
What exactly is wrong with yours?
FWIW, if that's the old white dial style, you can also swap in a needle style from a slightly newer truck. I think any cluster assembly from '88-94 should fit, and the needle-style clusters came online in the early 90's IIRC...
Looks like there are several on EBAY, but you'd probably get a slightly better deal at a junkyard...
Good Luck!!
Clemtiger84
