International 4300 Crew Box DT466 Eaton Transmission
bytortruck
International 4300 Crew Box DT466 Eaton Transmission 1 year unlimited mileage warranty $21,999
This is a extremely nice low mileage 2002 International 4300 with a DT466 and a Eaton Transmission. It only has 131,700 miles on it, and approximately 2500 miles on a overhauled motor that has a 1 year unlimited mileage warranty on it. Full size spare under the truck. The truck has air brakes, air suspension, air seats. It currently has a crew body on it that was over $130,000 new and some specs are below. The truck is missing the nets in the cargo area that are in the pictures.
The truck is rated at 25,999 GVW so no CDL is required.
This would make for a great Camper, overland, Moterhome, Toterhome, or Hauler Conversion. Also the box can be cut in half right above the tool boxes then you have a service truck. It is priced very well just as a cab with no box on it.
- Galvanneal 2" Thick Insulated Body
- 8 Person Crew Seating + 2 Person Cab = 10 Person Total
- Crew Compartment (Access from Rear of Body)
- HVAC System (Cooling 33,000 BTU, Heating 46,000 BTU)
- 8 Usable Exterior Compartments (15" Deep with Adjustable Shelving)
- Crew Compartment Overhead & Lower Shelving for Crew Gear
- Heavy Duty Vinyl Upholstery and Retractable Seatbelts
- 2 Emergency Exit Windows
- R14 Insulation in Ceiling and Side Walls
- Warning Light Package
- 3 Exterior Scene Lights
- Master Disconnection Switch
- Double Panel Compartment Doors
- Stainless Steel D-Ring Handles (Lockable)
- Structural Channel Subframe
- Shear Plate & Spring Body Mounting
- Compartment Lighting
- Painted Steel Interior Side Walls
- Floor coated with a rubberized coating.
- Spare Tire Storage Underdeck
- Body Painted to Match Cab
- 100 Gallon Fuel Capacity
- 4 Batteries
Call or text Brandon 206-225-6611 or email Brandonblarson@gmail.com
Here is a slide show of all the pictures. http://s29.photobucket.com/user/turbo94gto/slideshow/03 International 4300 Crew?sort=2
dgilmour
Looks like it was a hotshot crew buggy ( Forest Service, BLM , NPS fire crew Type 1 ) in its former life, is it 4X4?
