IntrepidXJ's Buildup Thread
IntrepidXJ
DaJudge said:
What was thinking behind going with the Y-link? Ride, flex, just wondering.
Main reason for going to the Y-link is the ride both on and off road.
I don't need anymore flex than I already get with my short arms.....I just want a better ride (especially when driving fast on the back-roads)
DaJudge
Thanks! Let us know how it goes. I was considering the Y-link for the same reason but I can't decide if it is really worth it. I look forward to your evaluation.
Glen
OverlandZJ
Exactly why i swapped to longarms. I got in on a group buy on RE components and picked up the RE lowers, and reused my existing uppers, combined with Clayton's crossmember. I wasnt concerned about clearance as i dont wheel much anymore.
Now to pick up a set of Bilsteins and limit straps.
IntrepidXJ
Fergie said:
Did you add your own mounts just to have a stronger attachment, or was it motivated by something else?
i raised the mounts on the axle 2.5" for better angles (same benefits of drop brackets, except with added clearance)
IntrepidXJ
Well, after spending 18 hours working on my Jeep yesterday with the held of Zach and Joe, we managed to get my T&T Y-Link suspension installed along with the T&T Stiffeners and Dana 30 truss. Also managed to get my RuffStuff 8.25 cover on and shaved the bottom of the 8.25 housing.
Here are some pictures from the day.
On the lift
Welding the Stiffeners on
I started myself on fire a few times ;)
Zach doing some welding
Front axle gone
Ruffstuff cover and shaved 8.25
T&T Dana 30 truss welded on
LCA mount gone
Hanging the front axle again
OverlandZJ
Lookin good Randy!
I found issues with my D30 housing, i need to swap everything over to a new housing and have it trussed.
IH8RDS
Randy,
What gear did you end up going with in tour TC for the speedo? I am running 4.56's with 31" tires. I belive that is what you are running. I couldnd find it in the thread.
I ran the no-slip for a couple years in my 8.25, until I upgraded to an 8.8 and ARB. I had no issues with the no-slip and it was a good locker.
Houie
