I've got a Vector 2000w vec054d inverter that I want to wire up to my 2007 GMC duramax truck. The inverter requires two #2 awg positive lines and two #2 negative lines and recommends a 300amp fuse. I plan to wire this to a 3rd isolated battery and not disturb the factory dual battery setup. I'm assuming its acceptable to run both positive leads to the same battery (obviously run time suffers as compared to each lead going to a different battery)? would it be possible to run a single heavier (like 1/0) to the inverter instead of the pair of #2 or maybe some sort of distribution block in the cab that would split the line just before the inverter? and finally, if i stick to the pair of #2 leads from battery to inverter, where does the 300amp fuse belong? just on one leg? a fuse for each leg (in which case 300amp seems a bit high for #2)? or do the legs converge and again split at the single fusable link?
any advice as to the best way to wire up this setup?
Thanks
-Rob
Thanks
-Rob
