IPF Wireless Remote/Switch Relay System for aux lights
ryhi
Brand new IPF wireless switch system for fog/driving/aux lights. Perfect if you don't want to go through the hassle of running a switch through the firewall. Simply wire your lights directly to the battery using this kit and you're good to go.
$60 shipped
unseenone
Any specs on that? Does it use the existing relay or does it have it's own relay? Do they make a two light set version of this, or can you use multiples?
ryhi
I'm not 100% sure on the specs since the manual is in Japanese, but the numbers say 12V 180W 15A. I would assume it means for a 12 volt system, up to a 180 watt bulb, at a15 amp draw. The kit uses its own relay. One kit is good for 2 lights only. You can use multiple kits for multiple lights as they have different channels/frequencies.
RC_X_Overland
