Is this possible for an onboard heated shower? - Quicktherm Heated Windshield Washer
bluehash
Might be a stupid idea, but the part is from Mopar for a heated windshield washer system.
http://www.justforjeeps.com/hewiwasosy.html
I was wondering if this could be plumbed out for a hot shower.. use the windshield washer pump since it is already in the jeep. Don't want to bathe in windshield washer fluid though.
Instructions for the part are here:
http://www.qwiktherm.com/pdfs/Jeep_Wrangler_2013-2015_3_6L.pdf
Or maybe just use the below one(no pump though)
http://www.amazon.com/AlphaTherm-AT-38OD-Windshield-Washer-Heater/dp/B0034GW1WW
IdaSHO
IDACAMPER
not nearly enough volume. Just too small.
Most of those Ive seen require a 20-30 second WAIT between uses simply for recovery time.
tarditi
My primary concern would be volume of water it can warm/pump.
From the description:
"Once installed, within 40 seconds after the vehicle is started a three to four second spray of heated washer fluid is available. After the first 4 second spray an additional 4 second spray is available every 15 seconds."
That's a pretty annoying shower, IMHO.
There are lots of commercially-available aftermarket on-board or portable water heater/shower systems - I would seek those out first.
Houie
