Isotemp Indel 15 - 4 gallon Water Heater with mixing valve- Utah
keithro
SOLD SOLD SOLD
Slimline 15 Water Heater
4 Gallons, 115V, 750W, 21.25"L x 11.38"Dia
With heat exchanger, stainless steel
New Open Box, never installed.
List Price $850.00
Sell For $350
Won't fit under my seat space....
Isotemp water heaters have earned a solid reputation for high quality and exceptional performance. The new basic product design builds upon the experience of 15 years and tens of thousands of water heaters sold. All Isotemp water heaters are designed specifically for the tough marine environment. Materials and components are carefully selected for performance and durability. Each tank is pressure tested for quality & integrity. Features:
The design allows both horizontal and vertical mounting options.
Highest quality in material (inner tank AISI 316, cover AISI 304) and welding, 2 years full warranty and 5 years limited warranty on the tank.
Foamed expanded polyurethane insulation, for lowest temperature loss.
Immersion heater element, especially designed to heat also the water in the bottom of the tank. The element (115 volt / 750 watt), is made of copper covered by nickel for longest lifetime.
Engine water heat exchanger coil is extra long for faster heating, especially good for sailing yachts.
Special safety valve on 87 psi, with a built-in two-way check valve, which reduces or prevents spill water by expansion. Simple winter drain.
All electrical installations ready Double overheat safety thermostat. Delivery includes power cable. Service thermostat set to keep the water above 160°F, to prevent the risk of bacteria.
Stable fixing feet in stainless steel adjustable 360°, for easier also bulkhead installation.
Thermostat mixing valve included.
Specifications: Gallons: 4
Dimensions: 21.25"L x 11.38"Dia
Weight: 23 lbs.
Max Pressure: 87 PSI
Immersion Heater: 115V/750W
